172 Users Online (171 Members):
Forums >> Revit Building >> Technical Support >> Wall sweep as footing join
0 Posts No Rating |
Hello, I have a problem with joining wall with footing (which is inserted as wall sweep). How can clean wall and footing joint. Wall is joining already correctly, but the sweep is not.
0 Posts No Rating |
I added revit file as well
I would rather use the Foundations (wall footing)in Revit for foundations. These clean up properly.
I agree with Tim. Don't use a wall sweep for a foundation, it's not really what it's intended for. Use the footing tool.
0 Posts No Rating |
Hei, yes this worked out well, but just wanted to know if there was other way as well. Later if I will use sweep on top or somewhere else then I will see if I come a cross on this issue again, but until then thanks.
Sweeps embedded in walls are hard to control, I avoid them as much as possible.
Continuous Wall Footing ? |
Thu, Aug 23, 2012 at 1:59:47 PM
13
Cut roof with wall sweep when join |
Thu, Jan 17, 2019 at 6:47:34 AM
Wall Sweep to Join with Window Family |
Thu, Aug 27, 2009 at 7:31:27 AM
can't put enough eccentricity to center footing on wall |
Tue, Mar 5, 2019 at 4:58:08 AM
Problem when applying a footing to wall |
Thu, Aug 23, 2012 at 1:58:50 PM
Members: | 1999122 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
