78 Users Online (77 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> The Studio >> how does view ranges work in ceiling views?
Mon, Apr 8, 2013 at 5:45:16 PM | how does view ranges work in ceiling views?
sllana
5 Stars: 2 Votes
Could anyone explain to me how do the view range settings work in the reflected ceiling plans?
A vertical squeme would be appreciate.
Tue, Apr 9, 2013 at 5:08:18 PM | how does view ranges work in ceiling views?
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
This might help . . .
https://docs.google.com/file/d/0B22tb0XxveQ8Mzk0ODdhZTgtNDdjOS00ZGIxLTliZTUtOGQxMDhiY2FjN2Zm/edit?hl=en_US&safe=active&pli=1&safe=active
Wed, Apr 10, 2013 at 7:26:00 AM | how does view ranges work in ceiling views?
teafoe5
teafoe5 Avatar
4.5 Stars: 46 Votes
DG great example
Wed, Apr 10, 2013 at 9:35:47 AM | how does view ranges work in ceiling views?
3.5 Stars: 391 Votes
You can download that sheet at: http://therevitkid.blogspot.com/2011/07/revit-tip-floor-plan-and-ceiling-plan.html
Tue, Apr 16, 2013 at 1:31:51 PM | how does view ranges work in ceiling views?
sllana
5 Stars: 2 Votes
Well, thank you very much to all of you. Lets begin a campaing for to make revit capable of adjust all those view range settings graphically in sections and elevations. What do you think?
Tue, Apr 16, 2013 at 1:39:15 PM | how does view ranges work in ceiling views?
Sections and elevations have nothing to do with the view range of the RCP.  Don't add to the confusion.
Tue, Apr 16, 2013 at 2:01:00 PM | how does view ranges work in ceiling views?
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
The fundamental flaw with controlling view range graphically from a section is that each and every floor plan and ceiling plan have their own individual set of view range properties.
Tue, Apr 16, 2013 at 2:17:09 PM | how does view ranges work in ceiling views?
sllana
5 Stars: 2 Votes
Everything is programmable. You can have a button to turn on and off the view range lines and a pull down menu to choose which level view range you want to show. For example.
Tue, Apr 16, 2013 at 2:38:02 PM | how does view ranges work in ceiling views?
But why from a section?  You can't see how that affects the RCP, you need to do it from RC plan.
Wed, Apr 17, 2013 at 8:12:48 AM | how does view ranges work in ceiling views?
sllana
5 Stars: 2 Votes
In the same way you can adjust the far cliping plane of a section in a plan view by dragging it. Just look the explanation: it is a section view, with dashed lines indicating the cut plane, the view depth plane and the top plane.......well you could dreg those dashed lines. That`s all
Fri, Oct 2, 2015 at 11:56:21 AM | how does view ranges work in ceiling views?
gurump
It would really help to set the range graphically. Something sim to the wall edit assembly box, instead of just inputting numbers.
Thanks dgcad for the illustration.
Fri, Oct 2, 2015 at 12:47:02 PM | how does view ranges work in ceiling views?
I find it interesting that nobody complains about view range for floor plans.   I believe this is simply an understanding issue.
Fri, Oct 2, 2015 at 1:28:31 PM | how does view ranges work in ceiling views?
#13
gurump
This is my official complaint for view range setup for flr plans as well.
Sat, Oct 3, 2015 at 7:44:27 AM | gurump
#14
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting gurump from 2015-10-02 13:28:31
Complaint Noted.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sat, May 11, 2019 at 2:42:35 PM | how does view ranges work in ceiling views?
#15
Leipert
Hey all, I made a video to help show the steps on how you can show a door in a Reflected Ceiling Plan in Revit. Enjoy!
https://www.youtube.com/watch?v=ZgzPf3zt39Y
Ceiling View Ranges: 2
Sat, Feb 23, 2008 at 9:25:24 PM
Ceiling View Ranges: Screen shot
Wed, Jan 4, 2006 at 11:36:28 AM
underlays, please help
Thu, Feb 26, 2009 at 8:52:25 AM
Create Work views
Thu, Feb 18, 2010 at 3:38:08 PM
Ceiling Views not showing
Tue, Apr 27, 2010 at 1:08:35 PM
Page generation time: 1.8188
