88 Users Online (85 Members):
Forums >> Workflow & Implementation >> Chameleon >> Installation Problems
admin
Please use this thread to post any problems with Chameleon installation. As always please read the instructions carefully and try to resolve the issue on your own before posting here.
thanks!
Hiroshi Jacobs
The Catholic University of America |
admin
If you want to install Chameleon for 2013, all you need to do is copy the install files to the 2013 Add-Ins folder. This is just a temporary fix until I update the installer.
- Install Chameleon for 2012 following the install instructions.
- Copy the files in this folder: C:\Users\*your user name*\AppData\Roaming\Autodesk\Revit\Addins\2012
- to this folder: C:\Users\*your user name*\AppData\Roaming\Autodesk\Revit\Addins\2013
- Open Revit
Edited on: Mon, Jun 4, 2012 at 9:51:38 PM
Hiroshi Jacobs
5 Posts No Rating |
i installed cameleon, but i havent got a Add-ins tab. i didnt have one before the install either.
any advice on how to get it working? im on architecture 2012 with a 64bit versino on Revit.
Thanks,Dan
admin
Hi Dan,
Try copying the files from the Install Revit folder of the downloaded zip file into the following folder:
Hiroshi Jacobs
Works just fine!
Thanks Hiroshi!
1 Posts No Rating |
I have downloaded the instalation file but when I open the ZIP and try to launch the setup a message appears saying there is an error with the file and it can be repaired, the same happens with the PDF users guide.
3 Posts No Rating |
i have tried installing using the install.bat file and the manual copying from 2012 addins to 2013 addins but neither has anything showing up in my addin's ribbon when I relaunch revit. are you sure this is still working?
thanks!
Revit Architecture Update #1 |
Tue, Jul 24, 2012 at 5:39:15 PM
Revit trial download problems |
Tue, Aug 4, 2020 at 5:06:23 AM
second nature installation |
Thu, Feb 17, 2011 at 6:39:14 PM
Installation problems with 2008 |
Sat, Mar 22, 2008 at 2:16:51 AM
my metric librarys gone? |
Thu, Apr 17, 2008 at 12:35:27 AM
Members: | 1998256 | Objects: | 22885 | Forum Posts: | 152180 | Job Listings: | 3 |
