145 Users Online (144 Members):
Forums >> Revit Building >> Technical Support >> Two Materials on a wall
What is the best way to make a wall with two materials on it. such as a waynes coating and then tile base at the floor.
For ceramic tile walls, we do our base wall with just the substrate. Then we add a veneer, stacked wall aligned with the face of the base wall. This stacked wall has the base, the wainscot and the chair rail - all with the correct materials. After you place the wall against the base, use the join tool to join this with your base. All of the openings and wall hosted objects will then cut the tile.
Edited on: Thu, Jan 12, 2012 at 9:53:15 AM
The answer here could depend on what your end result is going to be.
Do you need to schedule the materials?
Do you want accurate modeled material thickness?
Are you looking for material representation for rendering purposes?
Depending on what you need, you can fake materials by splitting the face and painting on a second material, you may decided to model the finish as a seperate wall type, you may decide to use a stacked wall...there are a few ways to accomplish this.
Consider the reason and choose the best method for that.
BTW - We have a resource project that already has several stacked tile walls set up as groups. Just copy paste the group into a room - ungroup / align the walls and join them - BAM - all done.
awesome. thanks WWhub.
And I do not need them in a schedule but do want the render materials
so where do I find this resource project? and are there walls with wainscoting on them?
thanks
You create the resource project. We maintain several of these in our library:
- Tile veneer walls
- Hatch patterns
- Doors
- Windows
- Toilet rooms
- Roof elements
- Typical Details
- Wall Types
Each of these are set up with the various compnents shown in views on sheets by category. Usually we show plan / elevation & 3D views so you can quickly find your objects and load them into your project.
so you mean you have just created this resource project?
thanks
Revit 2009: detailings: tag that list all wall's materials |
Mon, Oct 12, 2009 at 7:47:25 AM
Wall materials |
Thu, Oct 12, 2006 at 6:52:15 PM
Wall Types and Materials are not shown in Revit 2011 |
Mon, Apr 25, 2011 at 9:34:27 AM
Revit Wall materials |
Mon, May 5, 2008 at 1:58:45 AM
Section cut_ wall sweep causes materials to disapear |
Tue, Feb 2, 2016 at 12:44:28 PM
Members: | 1998451 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
