72 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Render
Thu, Nov 3, 2011 at 5:42:46 PM | Render
Akelley111
I am trying to render my 3D view in my project. Every time I do this, my background is completelly black even after applying color, image or adjusting.... I do not know what the issue is.. If you can help it would be very appreciated. Thanks   Revit Architecture 2011
Thu, Nov 3, 2011 at 9:57:12 PM | Render
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Are you rendering with Artificial Lights Only and don't have any light sources?  Screenshot would help.
Regards,
Chris.
Fri, Nov 4, 2011 at 4:33:26 AM | Render
Akelley111
I am rendering with exterior sun and a background image, but the background is blacked out, I have changed my image several times
Sun, Nov 6, 2011 at 12:55:02 AM | Render
Akelley111
Can anyone help me on this issue?
Sun, Nov 6, 2011 at 5:30:07 AM | Render
4 Stars: 201 Votes
You need to "Customize image", change the "Width" and "Height" and your background will appear.
Sun, Nov 6, 2011 at 7:29:31 AM | Render
Akelley111
tried that Typhoon... even tried to resave it as a template and reopen it as a new project still just a black background after I render
Sun, Nov 6, 2011 at 7:52:42 AM | Render
4 Stars: 201 Votes
Are you using a "Background" file like I post in my image OR are you using a "DECAL"?
Can you post some sceenshots like I post before so we can figure what's going on?
Sun, Nov 6, 2011 at 1:39:49 PM | Render
Akelley111
here is what it looks like rendered. I am not sure how to copy and save the screen shot to a jpeg
Mon, Nov 7, 2011 at 3:49:33 AM | Render
4 Stars: 201 Votes
Use "Sceenhunter" or "Jing" to capture your screenshots, is FREE
Mon, Nov 7, 2011 at 7:42:51 AM | Render
AbsoluteBIM
AbsoluteBIM Avatar
3.5 Stars: 3 Votes
or just hit 'Print Screen', open of paint and click the 'paste' button.
Mon, Nov 7, 2011 at 8:42:17 PM | Render
#11
Akelley111
what do I need to do..
Tue, Nov 8, 2011 at 6:15:13 AM | Render
#12
4 Stars: 201 Votes
Right now I can't test that but try this:
- Create a "CAMERA view" (not a 3D view like that) and render with that background.
Then post again a screenshot with the result.
Fri, Nov 18, 2011 at 1:14:18 AM | Render
#13
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Also, ensure the image folder location is mapped in your "Additional Render Appearance Paths"
Regards,
Chris.
Fri, Nov 18, 2011 at 2:59:41 AM | Render
#14
Dafpfy
3.5 Stars: 11 Votes
your render is 12000px / 4000px
i suspect that your background image is much smaller and is just in the center of your render but behind your model,
Kind regards,
D
Edited on: Fri, Nov 18, 2011 at 3:00:27 AM
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Render goes ok but when i change angle - the render is black
Tue, Oct 20, 2015 at 4:38:11 AM
Revit render or 3ds max design render?
Sun, Jan 4, 2015 at 10:19:29 AM
RENDER NOT HAPPENING...
Tue, Sep 20, 2005 at 5:00:45 AM
render masterplan
Sun, Jul 31, 2011 at 1:14:53 AM
I"M HAVING DIFFICULTY CHANGING THE RENDER COLOUR OF MY BALUSTER/STAIRCASE
Wed, Jan 19, 2011 at 4:52:18 PM
14
Page generation time: 0.3194
