103 Users Online (102 Members):
Forums >> Revit Building >> Technical Support >> Lighting cutting linked file ceiling... is it still not possible?
I know the one work around, lower the fisture. But I want to know if there is anything new in Revit 2012 that actually allows the family to cut a linked face... any help is appreciated.
To begin with, lighting fixture families need to be built in the Generic Model Face Based family template, not the ceiling template and not the generic model unhosted template. If it's not already in the Generic face based template, you'll need to rebuild it using the right template.
Once you have your family built in the correct template, create a Void Extrusion of the appropriate size and shape for the hole you want in the ceiling; using the Cut Geometry tool, cut a hole in the generic surface with the void extrusion. That should do it.
jlights |
You cannot have a families cut elements in linked files as yet. They can cut things in the host file only... But definitely agree face based templates should be used always for lighting.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
Lighting without ceiling |
Thu, Sep 10, 2009 at 11:02:50 AM
Why are my light fixtures on wrong side of the ceiling? |
Fri, Dec 13, 2013 at 9:38:09 AM
recessed Lighting for a curved ceiling or roof ceiling? |
Fri, Jun 27, 2008 at 11:06:24 AM
Ceiling dependent lighting |
Wed, Oct 24, 2012 at 12:21:07 PM
Ceiling grid lines will not show in the "existing" phase |
Thu, May 14, 2015 at 8:14:52 AM
Members: | 1998287 | Objects: | 22885 | Forum Posts: | 152180 | Job Listings: | 3 |
