96 Users Online (95 Members):
Forums >> Revit Structure >> Technical Support >> Pipe section profile displaying as a hexagon rather than circular (c/o mbsteve)
4 Posts No Rating |
mbsteve i've attached an image of my problem.
looks like you used a hexagon not a circle
4 Posts No Rating |
this is what it looks like when I click on it
Considering you are running Photoshope, a few IE's, Dropbox, Macafee and Revit 2010 plus who knows what else...I am guessing that you may be a little low on virtual memory (Revit 2010 and PS are huge VM hogs) and it may be causing some graphic regen issues...if it changes when you select it may be due to a screen regen...
You can hit the Function5 key and see if it regens correctly.
Circular handrail on curved stair |
Mon, Jan 7, 2013 at 8:23:25 AM
Custom Hexagon Curtain wall Panel problems |
Fri, Sep 25, 2009 at 1:25:51 PM
Trim HSS Round pipe into another HSS Round pipe |
Tue, Apr 3, 2012 at 4:39:45 AM
creating mass through solid sweep |
Sun, May 13, 2007 at 5:30:43 AM
Location of Pipe |
Wed, Feb 18, 2015 at 8:41:41 PM
Members: | 1998354 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
