157 Users Online (156 Members):
Forums >> Revit Building >> Technical Support >> batch pdf's
13 Posts No Rating |
Is there a (better) way to create pdf's than selecting them one-by-one?
I am using cute pdf and can create one sheet ok. When I select multiple sheets it asks me in a pop-up window for the file name, then the next window pops up before I can name the first one, etc.
I know cute pdf is not made for revit. Is there anything out there besides Acrobat pro that works?
Thanks a lot.
We use cute and it works fine.
With cute, you can combine PDF's in one file, otherwise the pop-up's do happen but they will be one behind the other.
Mr Spot has a manager program available: http://www.cadway.com.au/
I use PDFCreator, also can make other file types, combines, and free.
You should be able to preset the output location and disable the preview option.
We use Acrobat Pro and once you specify the output location in the Adobe driver and disable the preview we are able to print the PDF file(s) however we want and just let it run in the background...never get prompted for a file save location (name) or see a preview.
We also do this in Adobe Standard.
thanks everybody!
I will give it a try.
mpsteve, I tried out PDF creator and it creates the batch perfectly. Is there a way to have it automatically name the sheets the same way they are named in Revit instead of the numbers?
Thanks.
when you save the file you have the opportunity to name the file
thanks, but can PDF Creator automatically name the sheets based on how they are named in the revit file?
Autocad imports PDF's. Is there anyway Revit does that? |
Mon, Feb 1, 2010 at 5:06:18 PM
How to print different sheet formats in PDF? |
Mon, Jun 5, 2023 at 2:07:16 PM
Batch plotting folder location |
Thu, Jan 21, 2016 at 1:40:58 PM
Printing PDF's |
Tue, Oct 26, 2010 at 11:21:57 AM
Can't figure out PDF printing. Help! |
Tue, Sep 12, 2006 at 4:39:07 PM
Members: | 1998473 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
