Forums >> Revit Building >> Technical Support >> Changing different glass types in one curtain wall
3 Posts No Rating |
Hi, I'm trying to have colored, clear, and translucent glass in one curtain wall. I've tried selecting just the panel, unlocked it, and duplicated the type to the glazing i want, but it didn't work. I feel like im not doing things right, please help me!!!!!!!! I need a nice rendering for my final project~~ I really always appreciated all the help here!! =)
I would do different Panel families with different color material then load it in the project to use it in the curtain wall
Not Sure What Revit Can Do?... Find it OUT!!!
“Imagination is more important than knowledge...” -Albert Einstein |
"I'm trying to have colored, clear, and translucent glass in one curtain wall.I've tried selecting just the panel, unlocked it, and duplicated the type to the glazing i want, but it didn't work." Don't really know if this is what you want (see image), but you have to duplicate the material (glass) as well......
Edited on: Sat, May 29, 2010 at 10:39:30 PM
“Learning never exhausts the mind.” — Leonardo Da Vinci
"I would do different Panel families with different color material then load it in the project to use it in the curtain wall" ??? ???
3 Posts No Rating |
i figured out..lol i changed one panel to a generic wall and then changed it to a translucent material thanks!
If you want different panel types, simply select a panel [hover,tab,pick] then go to its type properties, select edit>new>duplicate. Change you newly created panel type to material, surface pattern etc. that you want. Repeat for as many panel types as needed. Then swap out panels in curtain wall to the ones you want. From the way your question was worded, it sounds like you need to brush up on instance vs. type parameters which is an essential Revit concept. Until you have a firm grasp of it Revit will remain a mystery. The HELP menu is a good start, but many good book out there as well.
Tom www.reviteer.com http://twitter.com/Reviteer |
0 Posts No Rating |
Hi guys
I have a similar question so I'm highjacking the thread. I want to do something that in my mind is super simple, but still haven't found a way to do.
I want to have a storefront, as it is built by Revit, only, for every part of it, only the middle panel to be glass, while the top and bottom should be opaque.
I want to somehow make it as default, and not have to select all 5000 single panels in my building one by one.. :D Any ideas?
There isn't a way to preset this. However you don't need to select them one by one, just select one then right click and hit select all instances in project then change them to what you want. You would then only need to go back and change the few you want to a different type.
So as teafoe says, set your base type as the opaque and then use a crossing window in elevation to pick the center ones and set those to the transparent.
Curtain wall: Change the glass colour? |
Fri, Aug 27, 2010 at 10:13:57 AM
Panel tags for glass doors with frame in curtain walls |
Thu, May 1, 2014 at 7:51:48 AM
Curtain Wall - Glass and Mullion Detail |
Tue, Oct 2, 2007 at 4:19:30 PM
curtain wall glass transparency |
Tue, Apr 19, 2005 at 2:41:00 PM
Curtain wall panels changing materials when pinned |
Fri, Feb 26, 2010 at 8:46:05 AM
Members: | 1999251 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
