66 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> component dimension
Tue, Mar 10, 2009 at 1:48:47 AM | component dimension
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
okay this one's got me stumped..
i have a joist component loaded into the project..
in the family editor it says 24 feet long..
in the project it measures 34 feet long..
i don't know how it got 34 feet- but i'm
now trying to make it 34' 4"..
and all it wants to do is move from side to side
and up and down- and i've tried everything
to change its length- and can't..
ha ha- just like the revit game puzzle that it is..
Tue, Mar 10, 2009 at 10:05:41 PM | component dimension
hjacobs
admin
hjacobs Avatar
3.5 Stars: 16 Votes
can you upload the family?  sounds like there's a parameter not working.
Hiroshi Jacobs
Tue, Mar 10, 2009 at 10:19:53 PM | component dimension
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
thanks jacobs-
i've been doing battle with this steel joist
for several days and it's just beating me
up at every turn..
i have four block walls- very simple 35x19
and ten feet hight..
all i want to do is learn how to get control
of a metal joist to put on top of it to support
a roof..  there doesn't seem to be a need to
take it into the family editor.. the ends of
it will set down on the top of the wall (level 2)
by offsetting the ends in the properties- but the
ends want to center on the wall and any other
length i create by rehosting won't won't go on
the wall top.. there seems to be so much to
know about operating these kinds of
components that i don't know where to
begin.. can you tell me anything about it?
thanks
Tue, Mar 10, 2009 at 10:37:04 PM | component dimension
hjacobs
admin
hjacobs Avatar
3.5 Stars: 16 Votes
I'm probably misunderstanding your question, but you can control the height offset and length of joists in the element properties.
see attached image
Hiroshi Jacobs
Wed, Mar 11, 2009 at 1:44:59 AM | component dimension
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
see that's what i mean- the length is grayed out..
i tried everything for days to get that to activate..
Show user created dimensions within Adaptive Component in Sheets (2016)
Fri, Jul 1, 2016 at 1:55:50 PM
Dimension or Detail Component?
Mon, Nov 18, 2013 at 3:24:16 PM
changing the reference of a parametric dimension
Wed, Nov 1, 2006 at 5:42:30 PM
Activate Dimension
Tue, Dec 13, 2011 at 12:53:44 PM
Embedded detail component scale issue
Mon, Oct 15, 2007 at 10:07:15 PM
Page generation time: 0.4660
